2002 Dodge Ram Rear Trans Bearing
GDSMITH
Is it possible to change the rear transmission bearing on a Dodge Ram 2500 two-wheel drive pickup without pulling out the transmission? It has 92,000 miles on the truck. It is a diesel. It is a 2002 year model. It is an auto-matic with overdrive transmission. It looks as though you could pull the back yoke from the transmission and accomplish it that way.
Jul 17, 2007 at 1:08 PM
DPWD23
  • 136 POSTS
Highly unlikely, although I am infamiliar with the exact transmission you have. That part that looks like it could be removed is called an extention housing. it generally contains the extention shaft, speed sensor, and rear seal. The rear bearing is further up in the transmission. And on top of that, most automatic transmissions are rebuilt by removing the bell housing in front, and the valve body on bottom to gain access to the inards. Replacing that rear bearing is one of the first steps in putting it all back together after an overhaul.
If you mean the rear seal because of leaking fluid at the drive shaft, that is possible. Just remove the drive shaft from the rear axle making sure to mark orientation, and slide it out if the tranny. Use a screwdriver or punch to VERY CAREFULLY get the old seal out, and use a socket or seal driver to drive the new one in.
Jul 19, 2007 at 4:27 PM
Suggested Repair
The rear transmission bearing generally cannot be replaced by removing only the rear yoke; it sits deeper in the transmission and is typically replaced during an overhaul. If the problem is a leaking rear seal at the driveshaft, remove the driveshaft after marking its orientation, carefully extract the old seal, and install a new seal with a socket or seal driver.
Conversation Summary
The owner of a 2002 Dodge Ram 2500 two-wheel-drive diesel with an automatic overdrive transmission asked whether the rear transmission bearing could be replaced without removing the transmission by pulling the rear yoke. The expert said that is highly unlikely because the visible extension housing contains the extension shaft, speed sensor, and rear seal, while the rear bearing is farther inside and normally accessed during an overhaul. If the issue is instead a leaking rear seal, that seal can be replaced after removing the driveshaft and carefully installing a new seal.
