2000 Dodge Ram 1500 Speedometer Delay
IRON MAIDEN
I have a Dodge 1500 2000 with 113000 miles with a 5.9 360 engine. engine light is on and speedometor does not engage til I reach about 55 mph. We changed the speed sensor located at the tranny but is still not working. whats up
Oct 30, 2007 at 8:07 PM
SERVICE WRITER
  • 9,123 POSTS
Run to the hills.....Run for your life.....
I haven't looked to see what set up this one has ( so forgive me if I'm wrong), but if you take out the speedo cable and rotate it manually, does it affect the speedo?
Oct 31, 2007 at 1:18 AM
SYNCRAIT
  • 235 POSTS
on top of the rear differential there is another speed sensor that is causing your problem replace it and everything should work fine. Its not a big job....Good Luck!
Nov 23, 2007 at 4:40 AM
Suggested Repair
Replace the speed sensor on top of the rear differential. The transmission speed sensor has already been replaced and did not fix the delayed speedometer.
Conversation Summary
A 2000 Dodge 1500 with a 5.9L engine has a check engine light and a speedometer that does not work until about 55 mph. Replacing the transmission speed sensor did not help. One reply suggested manually rotating the speedometer cable to see if the gauge responds, while another advised replacing the speed sensor on top of the rear differential.
