1999 Dodge Ram 2500 Axle Nut Stuck
CHRISTHEHEAD1
  • 8 POSTS
I have a 1999 dodge ram 2500 4x4 p-up 5.9l.I am trying to change my rotors on this truck.I have been struggling trying to get the center nut off which is approximately a 1&3/4inch socket to come loose.I am scared if I keep trying to force it I will damage the threads or something else.It is extremely tight and would appreciate any advice.
Nov 9, 2007 at 3:42 AM
BLACKOP555
  • 10,386 POSTS
your talking bout the one that holds the wheel assemply on the axel i hope? if so that one can take quite the pressure, make sure your using a 6 point socket not a 12 point also a impact would help it come off without to much tension.
Nov 9, 2007 at 12:40 PM
Suggested Repair
Confirm it is the axle nut holding the wheel assembly. Use a 6-point socket rather than a 12-point socket, and use an impact wrench so the nut can be loosened with less steady tension. The nut is designed to take substantial torque.
Conversation Summary
The owner of a 1999 Dodge Ram 2500 4x4 with a 5.9L engine is changing the rotors and cannot loosen the roughly 1-3/4-inch center axle nut, fearing thread damage. The expert says that nut holds the wheel assembly on the axle and can take considerable pressure. They recommend a 6-point socket and an impact wrench to remove it with less tension.
