1997 Dodge Truck replacing front rotors on 1997 Ram 2500 3/
HOMEBIZ
Brakes problem
1997 Dodge Truck Four Wheel Drive Automatic
We had the four back bolts out and the spindle lock nut off and could not get the front hub and rotor to come off. Is there anything else that has to be done to remove them?
Aug 26, 2009 at 12:54 PM
  • 110,248 POSTS
See if this helps. If it doesn't let me know.
Raise and support the vehicle.
Remove the wheel.
Remove the cotter pin and axle hub nut.
Remove the caliper with adapter and rotor.
Remove the ABS speed sensor, if fitted.
Back the hub/bearing mounting bolts off 1 / 4 in. each.
Tap the bolts with a hammer to loosen the hub/bearing from the steering knuckle.
Remove the hub/bearing mounting bolts and then the hub/bearing.
Oct 7, 2009 at 4:23 AM
