1986 Dodge Truck Rotor
1986 DODGE TRUCK
ACCTGLADY4
Brakes problem
1986 Dodge Truck V8 Four Wheel Drive Automatic
I can't find information on how to remove the rotor. All the books I have show a different type than what I see without the tire. The rotor on the truck is bent and it is causing other damage to the truck. Help!
Jun 19, 2009 at 4:36 PM
DR LOOT
  • 2,311 POSTS
your failure to be specific for example, Dana 44 front end, full time four-wheel-drive, hubs ect. I would just have to assume what you have. Remove the big nut in the center of the disc and then it should come apart the disc with the axle.
Jul 11, 2009 at 6:51 AM
