HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Truck
Engine
Symptoms
Not Running
SPONSORED LINKS
2003 Dodge Truck cranks but wont start
FISCHERSFTG
MEMBER
2003 DODGE TRUCK
Engine problem
2003 Dodge Truck Four Wheel Drive Automatic 140000 miles
cold today use diesel additive and is plugged in checked fuses and filter drain filter crankes but wont fire
Thursday, January 17th, 2008 AT 5:44 PM
JESSEKLAERNER
MEMBER
I was wondering if you ever figured out what the problem with your truck was because I seem to be having the same problem.
SPONSORED LINKS
Monday, February 18th, 2008 AT 3:25 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
Crank And No Start. Pulled Transmission And Now Won't...
I Had My Truck In The Shop And I Pulled The Transmission Because I Had Clutch Problems. Put The Transmission Back In And Found That My Cps (...
Asked by
Shredder1212o
1 IMAGE
1993
DODGE TRUCK
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
Will Not Start
I Have A 1998 Dodge 4x4 Ram 1500. Lights Will Not Go Out. Truck Will Not Start. I Checked For Spark, Their Is Non. I Changed The Coil...
Asked by
bigsoko
1 ANSWER
1998
DODGE TRUCK
1999 Dodge 6cyl Van Will Not Start
Eng Cranks Will Not Start No Power To Coil, Switched All Relays Fuel Pump Comes On With Key Then Shuts Off Also No Power To C.B. Labled...
Asked by
wild bill 48
1 ANSWER
1999
DODGE TRUCK
1997 Dodge 1500 Series With A 318 Engine Will Not...
Was Driving Stopped To Let A Friend Out But Did Not Shut Off The Engine, Drove About A Half Mile And Lost Power Truck Would Only Go A Max...
Asked by
tina74
1 ANSWER
1997
DODGE TRUCK
2002 Dodge Truck Starting Problem
Hello, When I Turn The Key, Sometimes The Engine Starts And Sometimes The Starter Will Just "click". The Click Will Occur Each Time I Turn...
Asked by
icedak02
2002
DODGE TRUCK
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
