2003 Dodge Truck
2003 DODGE TRUCK
154,000 MILES • 6 CYL • 4WD • AUTOMATIC
CLIFF4486
my truck want crank and i have a code that comes up (ecm/pcm power signal interm) what does that mean
Aug 20, 2009 at 12:16 PM
  • 110,244 POSTS
Is it a PO884, TCM Power Input Signal Interm? If so, the trans isn't telling the pcm that it is ok to start. I believe this could be the result of a bad neutral safety switch or a bad TCM or connection to the TCM.
Oct 7, 2009 at 4:57 AM
  • 110,244 POSTS
Also, I was thinking... This could have to do with an intermitent power problem to the TCM or a bad ground to the trans. Try this. Run a ground wire from the battery to the trans housing making sure the trans has a good ground. Use at least a 14 gauge or larger wire. After you do this, reset the computer and give it a try.
Let me know if this helps. Your trouble code could be related to a PO700.
Oct 7, 2009 at 5:08 AM
