1999 Dodge Truck 1999 Dodge 1500 5.2 with 111000
RAMTHISDODGE
  • 1999 DODGE TRUCK
  • V8
  • 111,000 MILES
The problem started the day befor I left on vacation. I was driving around the city getting everything ready for the trip and while at lights it would just die and would not start back up unless I held down the gas. I checked and cleaned the battery terminals becasue someone told me Dodges need perfect terminals, that had no effect on the problem. So I get back from vacation it had been sitting for 8 days, I start it up it starts to back fire and rev. I though maybe just a fule problem let me see if I can blow out a particle, I step on the gas no response still backfiring and running very irratic. It finely gets going and at about 20 to 25 mph it gets a sudden birst and runs like its brand new? I have to stop at the light and it dies and since then I have not been able to get here to run right. I put new rotor and cap on so far, just dont have a bunch of money laying around so I thought I would turn to the pros to give me some pointers. PS the fule pump works properly can here it running
Friday, August 29th, 2008 AT 12:55 PM
DOCFIXIT
  • 18,828 POSTS
I assume fuel filter is less than 30k and plugs are resonably new. Need to see if you have spark pull plug wire hold to block should be a blue/white spark. Next spray some carb cleaner into throttle crank it up if it runs need to check fuel pressure.
Let me know what you find
Friday, August 29th, 2008 AT 1:13 PM
