your answer does not answer my question Salva. I know the vacuum pump is connected to the timing gears and the power steering pump is attached to the vacuum pump.
now, the vacuum pump has to produce vacuum. the vacuum pump has to suck air to create a vacuum. the hole where the vacuum sucks air in order to create a vacuum,
thats where the vacuum hoses
are attached, now the hose, which sometimes called vacuum lines goes towards the back near the firewall which we call it the wall between the inside of the cab and the engine.
now my question again is , where are those vacuum hoses or vacuum lines connected to
or where they are attached to aside from being connected to the vacuum pump
as i said the vacuum lines is connected to the vacuum pump then it goes towards the drivers side then go acroos the left and then goes inside the cab. and i say again, there is a vacuum line dangling in there where i dont know where they are connected.
Dec 2, 2008 at 2:08 AM
