Engine Performance problem
1998 Dodge Truck V8 Four Wheel Drive Automatic
The truck will start, have replaced the Crank sensor, cap, rotor, plugs, and coil, and IAC valve. But will instantly die.
Sunday, March 15th, 2009 AT 2:26 PM
JDL
MECHANIC
Did you check for codes, anything? You should be able to access codes yourself?
If it refuses to restart right away, do some of the basic tests, spark at the pulgs, fuel pressure, injector pulse, engine cranking.
SPONSORED LINKS
Sunday, March 15th, 2009 AT 2:39 PM
MRCOMPTON
MEMBER
I'm doing this for a buddy to help him out. He didn't check the fuel pressure yet, and injector pulse? Engine cranks over, says there is crank sensor malfunction but replaced and no help.
Sunday, March 15th, 2009 AT 3:56 PM
JDL
MECHANIC
I'd check the sensor circuits on the cam and crank sensor both, they share ref voltage and ground. Check the asd relay circuits. Primary voltage for the coil--injectors, among other, gets voltage from the asd relay.
