1998 Dodge Truck clearing a 1389 code
1998 DODGE TRUCK
278,500 MILES • 6 CYL • 4WD • MANUAL
SPROCTOR79
How do you clear the 1389 code, no communications between the Automatic Shut Down relay and the PCM?
May 3, 2010 at 9:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if you have made the repairs then use diagnostic scanner to delete the stored code(s). if you have not made the repairs, check for faulty ground to the auto shut down relay, if OK check fuses and the relay itself.
May 3, 2010 at 9:38 AM
