[quote:f74bdc8bcd="wrench"]It sound like your ignition is cutting out thats the black smoke (raw fuel thats not getting burned up), and with the engine light comming on same time. So its not starving for fuel like you thought but either getting too much fuel or not able to burn the fuel its using. Next question is you say it does it at 70 mph or could it be doing it at a certian rpm. Now your truck is a '96 so it might be able to read engine troulble codes with out code reader, try this with the key switch turn ON-OFF-ON-OFF-ON dont wait to long between cycles the check engine light will then flash a code (have pen and paper ready to write down with) count how many blinks of light, if more than one code than there be about 4 to 5 second delay between. (example one flash pause four flashes 5 second pause two flashes pause two flashes = code 14 for the first and code 22 for the second)[/quote:f74bdc8bcd] The codes that i got from my truck are codes 12,43,51,27,24.could one of these be the problem.I put all new injectors,plugsand wires and it still does it?.
Sep 19, 2007 at 2:49 PM
