1994 Dodge Truck
ANTHONY98728
  • 1994 DODGE TRUCK
  • V8
  • 4WD
  • 99,000 MILES
HOW DO I GET THE BOLT OUT THATS HOLDING THE PIN IN IN THE GEAR WHERE THE SPIDER GEARS ARE THE BOLT BROKE OFF HAVE TO BUT THE AXLE BACK IN THE MOON CLIP CAME OFF WHY DOSE THIS HAPPEN PLUS NOW HOW DO I GET THE BROKING BOLT OUT
Sunday, July 18th, 2010 AT 4:31 PM
DR LOOT
  • 2,311 POSTS
You've really done it now, the problem with that bolt is it's very hard to get to, if you cannot drill it to get an easy out installed and even if you did you broke it off already there for the bolt is very tight, the only thing left to do because it is a special bolt with the sheer pin at the end you could try to take a big punch with a big hammer and hit the center lock pin until you break it off, if that does not work the only thing left to do is get a torch and cut the center pin so you can get the axles out and replaced the third member carrier.
Wednesday, July 21st, 2010 AT 3:13 PM
