2000 Dodge Truck Differential
65,000 MILES • V8 • 2WD • AUTOMATIC
KLOFT57
I was changing my rear wheel speed sensor and a 1/2 " square piece of plastic broke off and fell into the differential. Will this damage anything or should I drain differential fluid and remove plastic?
Jun 17, 2009 at 3:40 AM
CARADIODOC
  • 34,413 POSTS
I wouldn't panic. It might get chopped up by the gears, but it won't put up much of a fight. Eventually it will settle down in all the other crud in the bottom of the housing.
caradiodoc
Jun 23, 2009 at 7:31 PM
