1983 Dodge Truck stalling
KIRKDOUGLASIII
  • 1983 DODGE TRUCK
  • V8
  • 14,700 MILES
Thus is a low mileage truck. It starts like a dream. Idles perfect too. I have changed fuel filter plugs air filter and rotor. I have also cleaned carburetor.
Problem. Whenslowing down to make a turn, sometimes it stalls. Don't know why. It starts right back up again
Choke us clean and moves freely. What could be the problem?
Sunday, June 13th, 2010 AT 3:23 PM
NLINNANE
These particular engines had low compession and they had this particular problem right from the factory. So with this said When I got mine which is used had the exact same issue. The problem is to cold a heat range on the spark plugs, mine came came installed with from the previous owner with champion r12yc spark pugs which is actually one heat range hotter then the r11yc recommended by the factory, I went to Oreillys and they sold me champion r14yc spark plugs which they assurred me were now the correct heat range. Shure enough the truck now performs flawlessly. I also after driving it for a few days pulled one of the plugs just to see if their were any heat related issues with the plug and the plug looked great. By the way this truck I'm discribing is a 1983 royal 150 has the 318 with 2 barrel carb with 77,000 miles very clean 2 wheel drive.
Sunday, October 14th, 2012 AT 6:14 PM
