1977 Dodge Truck V8 Wheel Drive Type unknown Automatic 210000 miles
it stalls when I stop, then takes about 10 minutes I can start again. Then just 1 mile down the road it died again. Happened 3 times. Had a problem with the rods, had to replace one, and one seems as though its about 1/4 inch shorter then the rest. Thought maybe the rocker was tightened to tight and that the cam was flattened. Wondering if that could be the problem or just a electrical problem. Thank you for your time.
Friday, November 30th, 2007 AT 5:44 PM
