first pull the belt off of the car by pushing the tensoner pully down with a socket wrench, i beleive its a 3/4 socket or a 11/16 socket. then there should be 5 or 6 bolts going around the pump itself, (you may have to remove the alternator to get to it). when the pump is out take off the pully on the water pump itself,there not gonna give you a new one with the new pump. if your replacing the pump cause the car is over heating check the thermostat first, it should be located at the end of the upper radiator hose.
Sep 25, 2006 at 7:09 PM
