1997 Dodge Stratus Coolant Won't Drain
STEELWORKER
  • 12 POSTS
I found the coolant drain petcock on driver's side of radiator. after removing mid section above radiator I picked up slightly to tilt radiator back to allow turning of petcock and it doesn't work. I also tried sticking a wire up radiator mount above petcock to see if it was clogged, not a single drop. And please don't tell me to remove bottom hose, this would require removing the front grill, air bag sensors, breaking push fasteners, etc. How do I drain coolant????
P.S. -Chilton Book said it was on other side.
Is this a placebo petcock with no out??
Apr 28, 2007 at 9:58 AM
SERVICE WRITER
  • 9,123 POSTS
We just had a 98 cirrus in the shop and I remember the grumpy old tech moaning about it. That one was on the passenger side and the o-ring on it had to be replaced. He had to pull it out to get it to drain. He accessed it throught the parking ling light assy after removing it.
Hope this shed some light.
Apr 28, 2007 at 10:11 AM
STEELWORKER
  • 12 POSTS
[quote="Service Writer"]We just had a 98 cirrus in the shop and I remember the grumpy old tech moaning about it. That one was on the passenger side and the o-ring on it had to be replaced. He had to pull it out to get it to drain. He accessed it throught the parking ling light assy after removing it.
Hope this shed some light.[ no,, no light yet- already did the basic stuff to this car, replaced lower control arms /ball joints, valve cover & O-ring gaskets for spark plug tubes, recalled stuff for this car that previous owners didn't do. ]
Apr 28, 2007 at 10:29 AM
STEELWORKER
  • 12 POSTS
Well I see the answers are flooding in about this ,lol, Maybe I should put a hit on Dr. Z, lol
Apr 28, 2007 at 10:45 AM
Suggested Repair
On a similar 1998 Cirrus, the radiator drain was on the passenger side. Pull the petcock out to drain the coolant, replace its O-ring if needed, and access it by removing the parking light assembly.
Conversation Summary
The owner of a 1997 Dodge Stratus 2.4 could not drain coolant from the driver-side radiator petcock and did not want to remove the lower hose. A technician recalled a similar 1998 Cirrus whose passenger-side petcock had to be pulled out, had a worn O-ring, and was reached through the parking light opening. The owner said that information had not yet solved the problem.
