stuck in 2nd gear
TRIPB
98 dodge stratus, auotmatic trans, shifts fine, untill closed loop occurs, ck eng light on and will not down shift or upshift from 2nd gear... I added a can of trans X ... and that did nothing to improve the trans.. my feeling is a speed senser or other computer related failure, the car has 115,000 miles on it
Mar 19, 2007 at 5:12 AM
MULDOON
  • 79 POSTS
Check the transmission pack, I changed mine with same symptons, its not that hard but you have to have patience, on my 2.4 1996 its on the right side front near tranny, good luck Declan.
Aug 22, 2010 at 11:27 PM
MADMIKE1735
  • 951 POSTS
check input and output speed sensors.... usually they will have metal shavings stuck to the ends (their magnetic) howver i suggest replacing both of them....
Aug 31, 2010 at 12:51 PM
