1998 Dodge Stratus Stuck in 2nd Gear
TRIPB
98 dodge stratus, auotmatic trans, shifts fine, untill closed loop occurs, ck eng light on and will not down shift or upshift from 2nd gear... I added a can of trans X ... and that did nothing to improve the trans.. my feeling is a speed senser or other computer related failure, the car has 115,000 miles on it
Mar 19, 2007 at 5:12 AM
MULDOON
  • 79 POSTS
Check the transmission pack, I changed mine with same symptons, its not that hard but you have to have patience, on my 2.4 1996 its on the right side front near tranny, good luck Declan.
Aug 22, 2010 at 11:27 PM
MADMIKE1735
  • 951 POSTS
check input and output speed sensors.... usually they will have metal shavings stuck to the ends (their magnetic) howver i suggest replacing both of them....
Aug 31, 2010 at 12:51 PM
Suggested Repair
Inspect the input and output speed sensors for metal debris on the magnetic tips and replace both sensors. Also check the transmission solenoid pack, which has caused the same stuck-in-2nd symptom on similar Stratus models.
Conversation Summary
A 1998 Dodge Stratus automatic shifts normally until closed loop, then stays in 2nd with the check engine light on. Transmission additive did not help. One reply suggested the transmission solenoid pack; the expert advised checking and replacing both input and output speed sensors, which often collect metal shavings.
