2004 Dodge Stratus car won't turn on
NATIVEAUNT
Engine Performance problem
2004 Dodge Stratus 6 cyl Two Wheel Drive Automatic
I shut off the car about 10 minutes later i went to start the car again, and it started after about a minute it started to sputter like it wanted to stop and the engine light came on . I shut the car off and now i can't start the car. I was having trouble with the gas gauge marking it was not marking correctly now it marks that it is empty . I added two gallons of gas but it still wont' start
Sep 21, 2008 at 11:57 AM
BMRFIXIT
  • 19,053 POSTS
Need to check for fuel pressure
hook a fuel pressure tester and check
u can try to hit the mid of gas tank few times see if u can get the fuel pump to start again
if so
I would suggest replacing the fuel module
Sep 21, 2008 at 1:19 PM
