2003 Dodge Stratus rpms
TWINKEY1
  • 49 POSTS
2003 Dodge Stratus
2003 dodge stratus 2.4l....when driving and when slowing down to stop i notice the rpms jump up a little then go back down,is that a normal thing,it always happens around 1200 rpms then it comes back to 800 rpms before i stop.when driving the car,it drives normal
Sep 10, 2009 at 12:17 AM
  • 110,248 POSTS
Chances are the trans is shifting into first gear and causing it. Has the check engine light on?
Oct 8, 2009 at 5:54 AM
TWINKEY1
  • 49 POSTS
yes the engine light has came on,i checked the codes and its pulling an eavap code,nothing on transmisson codes,was told it was normal,it jumps a little,just in case you wanna speed up again,dont know
Oct 8, 2009 at 9:41 AM
  • 110,248 POSTS
Honsly,
It sounds normal, as if it is down shifting. As far as the evap codes, have you had that checked?
Oct 8, 2009 at 2:31 PM
TWINKEY1
  • 49 POSTS
i havent had the car checked,i been driving the car for 3 months since the evap code came on,its been driving normaly no problems,excpt i notice once in awhile gas milage is diffrent
Oct 14, 2009 at 5:23 PM
  • 110,248 POSTS
What I suggest is to have the system fogged. What they do is fill the system with fog. If there is a leak, the fog will be seen coming from it. THen they will know where the problem is.
Oct 15, 2009 at 6:47 AM
