1996 Dodge Stratus RPMs
ALBGOOD
  • 1996 DODGE STRATUS
1996 Dodge Stratus 96000 miles
I was driving my car when I noticed that the RPMs were higher than normal. As I sped up, the RPMs increased and remained high. For instance, I was going 20 mph at 2 rpm then 30 mph was 3 rpm. It kept increasing. Any ideas on the problem? Thanks.
Wednesday, July 15th, 2009 AT 5:39 PM
MERLIN2021
  • 17,250 POSTS
Does it seem like the engine RPM is actually increasing, or is it a false RPM reading?
You can try a self-diagnostic test. To activate self diagnostic program:
With the ignition switch in the OFF position, depress the TRIP and RESET buttons.
While holding the TRIP and RESET button turn the ignition switch to the ON position.
Continue to hold the TRIP and RESET buttons until the word CODE appears in the odometer windows (about five seconds ) then release the buttons. If a problem exists, the system will display Diagnostic Trouble Codes (DTC's). If no problem exists, the code 999 (End Test) will momentarily appear.
Thursday, July 16th, 2009 AT 9:07 AM
