2003 Dodge Stratus Pleassssss help iM starting a new job an
ENJOYINGLIFE86
  • 2003 DODGE STRATUS
  • 6 CYL
  • FWD
  • 100,005 MILES
I drove it to the store about 3 blks away and when I tried to leave it would not even turn over. I have power to my lights, windows ect, but not to my radio. I checked my battery connections and they were solid I checked my fuses and I found I small 20 amp fuse to the start\fuel that was blown I did not have an extra so I robbed the abs 20 amp fuse I tried to start the car and it didn't do anything different I checked all the other fuses did not see any obvious blows (not sure about the bigger covered ones) I ended up getting pushed home by a friend that happened by while being pushed I noticed a trouble code come up?(I think) it was where my mileage usually is and it said either bu5 Or bus I have next to no money and am starting a new job that I have no clue how I am getting to in the morning im pretty car savvy at least I can take a motor out and apart and put it back together but im lost here
Thursday, September 9th, 2010 AT 11:25 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
You will have to replace all the correct fuses and than you will have to get a scan done, a BUS error is a communication problem with the ECU / computer, we will have to know the exact code to go any further.
Mark (mhpautos)
Friday, September 10th, 2010 AT 2:30 AM
ENJOYINGLIFE86
I changed the fuses including the one I robbed from the abs, pushed the car to auto zone and had them hook up the obd2 computer and it said that everything was good do I need a different kind of check/ scan, could it be the ignition module OR coil and if so cant I check that by jumping the starter with a screwdriver and bypassing the normal sequence also the original code said no bus or no bu5 not just bus or bu5 dont know if that makes a difference, if I have to run another test on the ecm could I just take it out and bring it to a shop instead of haveing it towed cause im runnen out of favers quick it sits towards the top by the fuses and does not look to complicated, also if I should try the bypass correct me if im wrong the starter for my particular car should be up by the back side of my oil pan covered by my muffler
Friday, September 10th, 2010 AT 10:33 PM
Hi enjoyinglife86, Welcome to 2carpros and TY for the donation this is what keeps the site going to help people in need and to cut costs
Let me asked you this: Is it cranking over and will not start or just won't crank at alll/nothing when you turn key to starting position
Saturday, September 11th, 2010 AT 10:02 PM
