2003 Dodge Stratus locations
TWINKEY1
  • 49 POSTS
2003 Dodge Stratus 4 cyl
trying to find where the Charcoal Canister and EGR are on a 2003 dodge stratus 2.4 DOHC sxt
Jun 4, 2009 at 3:00 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The EGR valve should be located in the rear of the engine...close to the firewall directly in the center while the canister will be located on a bracket towards the front of the fuel tnak.
Jun 4, 2009 at 3:08 PM
TWINKEY1
  • 49 POSTS
can i access the EGR from the top or under-is the canister hard to get to if the car is jacked up
Jun 4, 2009 at 3:15 PM
BLUELIGHTNIN6
  • 16,542 POSTS
EGR is little tricky to reach. Smaller hands help here. Canister should be easily accessed with vehicle raised.
Jun 4, 2009 at 3:28 PM
TWINKEY1
  • 49 POSTS
is it easier to go from the top or bottom for the EGR
Jun 4, 2009 at 3:57 PM
BLUELIGHTNIN6
  • 16,542 POSTS
top
Jun 4, 2009 at 4:01 PM
TWINKEY1
  • 49 POSTS
thanks for your help,i been getting a code p0440 it comes on for a few days then it would go out-the check engine light,i got a new gas cap from auto zone,im trying to figure if thats the issue and should i get a cap from the dealer instead,plus when i pulled the codes today i got the p0440---plus a P0441 Evaporative Emission Control System Incorrect Purge Flow
Jun 4, 2009 at 4:07 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Ew, nasty codes. Hard to find the cause of this trouble code. Could be anything from a leak in the EVAP emission system to a faulty EVAP purge solenoid or vacuum supply. Your doing the right thing by starting off with the smaller stuff though.
Jun 4, 2009 at 4:12 PM
TWINKEY1
  • 49 POSTS
if theres a leak would the check engine light contently stay on,it dosent come on when in driveing,just when i start it,it would come on for a few days then go off for about 4-5 days
Jun 4, 2009 at 4:55 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Its supposed to come on when starting, its called a bulb check. If it doesnt stay on while driving then there shouldn't be any faults.
Jun 4, 2009 at 4:59 PM
TWINKEY1
  • 49 POSTS
i know it suppose to come on when i start the car,if theres a leak in the evap system,wouldnt the light stay on and would it come back on when im driving after i clear the codes
Jun 4, 2009 at 5:22 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, the light should stay solid and yeah it will come back after driving it a certain amount of miles or after a certain number of ignition cycles.
Jun 4, 2009 at 5:26 PM
TWINKEY1
  • 49 POSTS
you been very helpful thanks alot,i see,the light doesnt stay solid,it gos off for a few days then it would come back,its driving me crazy,just hoping the gas cap is the reason,like i said,its new from auto zone,just wondering if i need the right gas cap from a dealer
Jun 4, 2009 at 5:38 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If its just a universal gas cap then yes, i would recommend getting another from straight from dealer
Jun 4, 2009 at 5:39 PM
TWINKEY1
  • 49 POSTS
it is a universal cap,got it for 6.00 bucks
Jun 4, 2009 at 6:08 PM
