quick connect
2005 DODGE STRATUS
122,000 MILES
JC88
  • 8 POSTS
hi i have a 05 dodge stratus and am getting a trouble code for small evap leak. i checked all fuel lines and beleive i found the peoblem, its a quick connect that goes into the fuel rail. the quick connect is the part thats broken because it moves back and forth freely, i tried replacing the retainer clip but no good. can you tell me in detail how to replace this part?
Apr 25, 2013 at 1:41 AM
HMAC300
  • 48,601 POSTS
see if it's missing an oring there that may be the problem.
Apr 25, 2013 at 2:40 AM
JC88
  • 8 POSTS
thanks for your reply hmac300. i read up on the part and it says theres a non-servicable o-ring inside it, i figured that was the problem but i have to buy it as a whole peice. it comes as a kit with the quick connect boot (i say boot bcuz its an elbow shape) already connected to a peice of fuel line. the other end has nothing but it comes with a barbed coupler thing to fit inside it. so im guessing i have to cut the old one off? i cant find one with quick connects already on both ends of a hose? i also dont know what size line or connector i need. lol i feel stpid for asking all these questions. ive got to go to work soon so i wont be able to reply right away if you have more answers, thanks again for your help tho!
Apr 26, 2013 at 2:07 AM
HMAC300
  • 48,601 POSTS
yes you'll have to cut one off . you could find the whole line but it will be at a dealer and will be apremium price.
Apr 26, 2013 at 2:25 AM
HMAC300
  • 48,601 POSTS
you'll have to cut the line then put a clamp on it so it won't come off a sharp knife can cut the line
Apr 26, 2013 at 2:29 AM
JC88
  • 8 POSTS
oh wow u already replied lol thanks a bunch boss! its under pressure so im guessin it one of those things where u gotta boil some water to get that barb into the line
Apr 26, 2013 at 2:30 AM
