EVAP not ready
152,000 MILES • 3.0L • V6 • FWD • MANUAL
JOE WILKIEWICZ
Just did a tune up (new plugs, wires, intake and valve cover gaskets, vacuum lines) which required taking the intake manifold off. When I reassembled, had a vacuum leak that tripped a P0401 code. Put some of the old vacuum line back on, solved that problem. But now the EVAP readiness test will not complete. Been driven for about a week, both freeway and city driving. No check engine lights. The car also has an AEM cold air intake installed, but ran fine with it before the tune up.
May 12, 2017 at 9:57 AM
STEVE W.
  • 15,409 POSTS
Get a factory scan tool and see if it has codes stored that a "common" reader does not see. There are specific parameters to set the readiness monitors and a hidden code could stop the test from running, even when nothing else seems wrong.
May 12, 2017 at 11:21 PM
