2002 Dodge Stratus Radiator/heating problem
2002 DODGE STRATUS
155,000 MILES • 4 CYL • FWD • AUTOMATIC
ACHICKE
My 2002 dodge Stratus started leaking anifreeze a few weeks ago. When it was low on antifreeze, the heater would not blow hot air. When we added antifreeze the heater worked fine. We recently added some stop leak for the radiator and antifreeze and now the heater is blowing nothing but cold air. Before we added this, the heat gauge would get a little warm and now it seems fine. What needs to be fixed and how much should this cost?
Apr 28, 2009 at 7:22 AM
  • 110,194 POSTS
It sounds like the product you used may have plugged the heater core. Remove the heater core hoses and see if you can force water through the core. Just use your garden hose.
Let me know what you find.
May 6, 2009 at 11:06 PM
