Engine overheats?
ZACKMAN
  • 4,202 POSTS
Overheating at idle (like at a stop light) or while you are driving? Did you notice the radiator fans turning on once it is overheating? If it overheats, does it bring the temperature down by turning on the heater full blast?
Saturday, December 5th, 2020 AT 10:02 AM (Merged)
TOPNOTCHCHICK
  • 5 POSTS
  • 2002 DODGE STRATUS
  • 149,000 MILES
"i have a 02 and all of a sudden out of nowhere it start running hot and cutting off on me. The heat also just stop working. When it hits hot when I press on the gas I start hearing a noise and the engine starts to kinda tick then it cuts off.
Saturday, December 5th, 2020 AT 10:03 AM (Merged)
  • 109,885 POSTS
The engine's overheating will cause it to shut it down. The noise is because the oil is thinning out due to heat. Try not to run it that hot.
Does the engine overheat at highway speeds or only while stopped? Have you replaced the thermostat? Is the coolant clean and full? Has the radiator ever been flushed or cleaned?
TOPNOTCHCHICK
  • 5 POSTS
Yes it start over heating on the high way and when I stop it would cut off. I do have coolant in it but I do have a leak somewhere because it keep running out. I just got my thermostat changed but haven't started my car because the battery is dead. Do you know what the problem could be?
  • 109,885 POSTS
You need to locate the coolant leak and fix it first. As far as the battery, it could be weak due to trying to start it over and over. Recharge the battery and fix the leak. Make sure the coolant is full and try starting it. At that point you will know if it will start. If it doesn't let me know what is happening so I can further direct you.
  • 109,885 POSTS
PS: You lost heat because there was no coolant in the system.
TOPNOTCHCHICK
  • 5 POSTS
In order to get the leak fixed I would have to move the car do you think its going g to over heat and cut off? Because it had coolant and oil and it was over heating after I got off the high way. I just don't want to get stuck or mess the problem up more
FLORIDA SUNSHINE
Engine Cooling problem
2002 Dodge Stratus Automatic 90K miles
I'm in the market to purchase a used car. I found one in my price range that has the following problem. Car needs a tune-up as it overheats (leek in coolant and might need new thermostat). Leek in A/C system as well.
How much would an estimated cost be to get these problems fixed?
BILLYMAC
  • 2,204 POSTS
Hi sunshine
In most cars this may be a simple prob. BUT not with this one. Depending on where it is leaking. This could cost less then 100 or it could cost 2000. So you really need to know where the coolant leak is.
And tune up will not be related to coolant leak or overheat. BUYER BEWARE of these cars. Good luck billymac
  • 109,885 POSTS
If this is a problem you can't fix, I wouldn't recommend driving it. It could cause more damage. If it is leaking the coolant, it will overheat again.
TOPNOTCHCHICK
  • 5 POSTS
I got a new battery and the car won't start it sounds like its about to but I don't
  • 109,885 POSTS
I have no idea how overheated it was. There could be engine damage. If you are getting spark and fuel to the engine, you need to check engine compression. You may have taken a head gasket out or warped a head causing a loss of compression.
Did you locate the leak?
TOPNOTCHCHICK
  • 5 POSTS
No spark. So I had the spark plugs changed. It still didn't start. This machanic said he couldn't find out the leak untilled be starts it up. Since it haven't been running it haven't leaked the coolant is still filled
  • 109,885 POSTS
They could pressurize the cooling system with a small hand pump to look for leaks. If there is no spark, have him check the crank sensor.
2CP-ARCHIVES
  • 4,540 POSTS
Ok so a few days ago the heat went out in my car but the fan/ blower still works it just blows out cold air. But, when you drive it the heat returns. Now today the car over heated and was all the way on H. What could be wrong?
CARADIODOC
  • 33,916 POSTS
The most common cause is the coolant level is too low to circulate through the heater core in the dash. That was the warning that might save the engine. Now it's low enough that it's not circulating through the radiator. The overheating is a common cause of a warped cylinder head which will leak coolant, and a leaking cylinder head gasket is a common cause of coolant loss that leads to overheating. Your mechanic can do a chemical test at the radiator cap to test for a leaking head gasket. If it needs to be replaced, once the head is off he will check it for warpage. If it is warped it will need to be machined or straightened, depending on which engine it is.
AKC400
  • 4 CYL
  • FWD
  • 60,000 MILES
My car keeps overheating and the engine coolant keeps backing up into the reservoir. What is wrong with my car?
STEG0687
  • 5 POSTS
The first thing I would check is the thermostat and then check your radiator. Sometimes but not very often they will get blocked. An easy way to check this
is after your car is warm, feel both the uppper and lower radiator hoses, they should both be hot and about the same temp.
AKC400
Yea the top hose getting hotter and the bottom hose is way colder. How do I find and get rid of the blockage?
