HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Stratus
Engine
Symptoms
Overheat
Car stalls when it gets hot
STOLTZIE
MEMBER
1998 DODGE STRATUS
200,000 MILES
Check engine light comes on blinks and car stalls when it gets hot
Monday, February 1st, 2016 AT 7:58 AM
JOHNNYT73
MECHANIC
Go to parts store if you can to have them retrieve the codes for you
Monday, February 1st, 2016 AT 8:16 AM
STOLTZIE
MEMBER
1 POST
Bweny there done that some sensor codes came up j changed coil, plugs, wires, cam shaft sensor and crank sensor?
Monday, February 1st, 2016 AT 8:20 AM
JOHNNYT73
MECHANIC
Ok, well this is important information.
Monday, February 1st, 2016 AT 8:21 AM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
Engine Overheating Problem?
My Water Pump Went Out On My Car. We Replaced It, And The Timing Belt. ( It Is In Time). We Cranked It Up, And Filled All Of The Fluids In...
Asked by
laurenm
2006
DODGE STRATUS
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
I Have A 1999 Dodge Stratus And I Have Replaced The Water Pump And The Thermostat And Put A New Radiator Cap On I Still Have The Problem...
Asked by
likemack
1999
DODGE STRATUS
Engine Overheats?
My 2002 Dodge Stratus Overheats After Traveling 30 To 45 Minutes. The Radiator Overflows Into The Overflow Tank Thus Causing The Over Flow...
Asked by
Leekins
2002
DODGE STRATUS
Engine Started Over Heating?
Was Driving And Car Alarm Went Off, Car Started Over Heating. So Steam Coming From Under The Hood. But No Fluid On The Ground. Then I Added...
Asked by
submarmon
1997
DODGE STRATUS
Engine Keeps Overheating?
Changed Water Pump, Heater Core, Thermostat, How Can I Check To See If It Has A Blown Head Gasket, That Is Blowing Compression Back Into...
Asked by
stepside
2001
DODGE STRATUS
VIEW MORE
Coolant Leak Symptoms
