Hi Guys, Here's my problem...
The car simply won't start...The first mechanic said that the injectors were'nt getting any fuel...i've switched out the fuel pump, the crank position sensor and the fuel pump relay. In the process of buying a front ecu! One mechanic said it even could be the harmonic balancer...sounds expensive. I need some good sound advice. Can you help?
Dec 18, 2009 at 4:38 AM
