I have a 2003 Stratus and mine is located in the fuel tank.
Monday, August 6th, 2018 AT 12:56 PM
(Merged)
LINNYLOUV
MEMBER
1 POST
1998 DODGE STRATUS
1998 Dodge Stratus 4 cyl Front Wheel Drive Automatic
where is the fuel filter located
SPONSORED LINKS
(Merged)
JNOVACK
MECHANIC
It is located Under vehicle, passenger side, below seating area, front of fuel tank, mounted on frame in fuel line
(Merged)
LIL_ROOS_MAMA
MEMBER
1 POST
1999 DODGE STRATUS
6 CYL
FWD
AUTOMATIC
135,148 MILES
Where is the fuel filter located?
(Merged)
BILLYMAC
MECHANIC
Hi the fuel filter is under the car find the lines comeing out of the gas tank filter will be near them. Good luck billymac
SPONSORED LINKS
(Merged)
BLUELIGHTNIN6
MECHANIC
Under vehicle, passenger side, below seating area, rear of fuel tank, mounted on chassis in fuel line
Monday, August 6th, 2018 AT 12:57 PM
(Merged)
KSCOTT91109
MEMBER
1999 DODGE STRATUS
1999 Dodge Stratus 4 cyl Four Wheel Drive Automatic
i just need 2 no where is the fuel filter on a 1999 dogde stratus
(Merged)
JDL
MECHANIC
Welcome, my info says it is located under the vehicle, passenger side, front of fuel tank, on frame rail.
(Merged)
WHISTLEDGM
MEMBER
1 POST
1997 DODGE STRATUS
4 CYL
FWD
AUTOMATIC
95,000 MILES
Can you tell me where the fuel filter reset switch is located? My daughter ran her car low in gas. The engine will turn over but won't start. The fuel pump is engaging when you turn the swtich on.
(Merged)
SERVICE WRITER
MECHANIC
There is no reset on this one.
Try spraying some carb cleaner or starting fluid into the throttle body and see if it runs for a minute or not.
(Merged)
DAWANDER
MEMBER
1 POST
2000 DODGE STRATUS
4 CYL
FWD
AUTOMATIC
600,000 MILES
HOW DO YOU CHANGE A FUEL FILTER IN THIS CAR?
Monday, August 6th, 2018 AT 12:58 PM
(Merged)
TWINKEY1
MEMBER
1 is in the tank. The other is right next to the tank, under the mounting strap bolt.
SPONSORED LINKS
(Merged)
JAYDESMOMMY
MEMBER
1 POST
1999 DODGE STRATUS
4 CYL
AUTOMATIC
How much do u think it would cost me to take my 99 dodge stratus in to get the fuel filter changed? I am a female so I have no clue. Lol
(Merged)
WRENCHTECH
MECHANIC
The frame mounted filter calls for 1 hr labor so calculate that by the shop.S labor rate.
