2001 Dodge Stratus Blown Gasket Head
2001 DODGE STRATUS
90,000 MILES • 6 CYL • FWD • AUTOMATIC
KITTY329H
We started having trouble getting both our heater and air conditioner to work properly consistently so we took it into the shop to get it fixed, as we had the money and it was getting rather annoying. They said that our thermostat housing had gone bad and charged us $400 to replace it. The next day, as we were driving home from school, all of a sudden the engine started overheating, and within about a minute all the bells and whistles had gone off. We took it back into the shop and they kept it for about 6 weeks, then gave it back, saying they didn't know what was wrong and that we would have to take it somewhere else, it was still overheating badly. A friend mechanic of mine said that they hadn't properly bled the system and that an air bubble had probably caused the car to overheat the first time. He bled the system, but it continued to overheat. Finally, we took it to a dealer, who promptly identified a blown head gasket, which would cost about $1400 in labor alone to fix.
I and a few others think that the shop we took it to improperly bled the system when they replaced the thermostat housing they improperly bled the system, which left an air bubble and caused the car to overheat, which resulted in the blown head gasket. I was wondering if my thoughts could be correct, as it had never before overheated until the housing was replaced. Do you think there is a way we could get the shop to pay for the damages, or are we on our own? Any help or opinions on our options would be greatly appreciated.
Apr 19, 2008 at 3:21 AM
SERVICE WRITER
  • 9,123 POSTS
I see no connection to the air conditioning and the thermostat housing. With the exceptionof the colant temperature getting too hot and shutting down the compressor.
Had you been having to add coolant at all pror to this...I assume you were checking it.
If it started overheating it should have been immediatly shut off...unless you were in some sort of danger.
I would suggest calling the shop and talking to the owner and explaining what is going on and ask them if they are willing to do something . I wouldn't be aggressive about it. I think if they shop is straight up , they will help out in some way.
The other option is to go to court, and I think there is a fair chance you would win.
It isn't very promising that they are going to help as they kept it for 6 weeks and couldn't figure it out. If they were busy, i might understand a week.
Your prognosis is very possible, if they also replaced the t-stat, it may have been defective as well. It is also possible that they left an open in the system that leaked.
My gut feel is this will end up in small claims court.
Apr 19, 2008 at 2:32 PM
