Stalls and shuts off when accelerating
STEVEPOONS
  • 12 POSTS
  • 2000 DODGE STRATUS
  • 6 CYL
  • FWD
  • 191,000 MILES
I have an ES, V6 that seems to not run in idle. The vehicle starts up just fine, but does not idle. It just shuts off instantly. I can give it gas to keep it running, but as soon as I let off the gas the rpm's just drop to 0. There does not seem to be any gas getting to it.
Wednesday, July 25th, 2018 AT 5:03 PM (Merged)
FIXITMR
  • 9,990 POSTS
Sounds like IAC valve is malfunctioning.
2CP-ARCHIVES
  • 4,540 POSTS
  • 180,000 MILES
Drove through a puddle of water this morning was bigger then I thought car shut off and has not started since. What should I do?
WRENCHTECH
  • 20,761 POSTS
It depends where that water ended up but it is possible to do real severe damage that way. If it sucked water into the intake, remove all the spark plugs and crank the engine to dump the water out. If they engine does not crank, it may already be too late.
