1998 Dodge Stratus fans don't turn on
HJACKMA51982
1998 Dodge Stratus 4 cyl
The cooling fans on my stratus don not tun on unless the AC is on. we have replaced the coolant temperature sensor to no avail... given that it turns on when the AC is on that would indicate that the relays aref ine wouldn't it?
please help
Aug 16, 2010 at 1:46 PM
  • 75,988 POSTS
Sounds like the computer controlled of the low and high fan relays
Aug 16, 2010 at 2:00 PM
HJACKMA51982
My apologies... I am really not very mechanically inclined... I am not sure what to make of your response. Would it be possible to clarify a bit?
the only thing that come to me from it is that I may need to replace the main computer int he car.
Thank you for replying I really do appreciate it.
Aug 17, 2010 at 5:03 AM
  • 75,988 POSTS
The computer picks up an input signal from the coolant temperature sensor to activate the fan relays in a given engine temperature. Check and test the thermostat its job is to control the engine temperature and the CTS reads it then reports this data to the computer
Aug 17, 2010 at 6:48 AM
