1992 Dodge Stealth Oil Leak
CARLYNSW
1992 Dodge Stealth ES, manual. 225,000 miles...Anyone have any tricks/tips on an easy way to track down the source of an oil leak?? I have oil dripping from somewhere on the driver's side of the engine but can't seem to locate the origin. I tried to follow the oil trail but lose it between all the parts and wiring.
Jul 25, 2006 at 3:31 PM
VANDRAGON
  • 298 POSTS
it sounds like the oil pressure switch or as some call it the oil sending unit. it screws into the motor near the rear of the engine. look at a manual to find the location. it could be the valve cover gasket also. try pulling the cover down with the bolts a little tighter.
Jul 25, 2006 at 11:27 PM
SERVICE WRITER
  • 9,123 POSTS
You can buy "dye tracer" and add it to to oil, that may help pin point the origin. Most parts stores carry it.
Jul 27, 2006 at 9:17 AM
Suggested Repair
Inspect the oil pressure switch (sending unit) at the rear of the engine and the valve cover gasket; snug the cover bolts slightly if needed. Add oil dye tracer to pinpoint the driver's-side leak.
Conversation Summary
The owner of a 1992 Dodge Stealth ES with 225,000 miles has oil dripping on the driver's side and cannot trace the source through the parts and wiring. Experts suggested the oil pressure switch or sending unit near the rear of the engine, a possible valve cover gasket leak, and dye tracer to locate the origin.
