2003 Dodge Sprinter Front Bearing Removal Fix
RB FRENCH
I Have a 2003 Dodge sprinter 2500 with 48K miles and I'm replacing the brakes and want to repack the front wheel bearings. I was easily able to remove the outer bearing, but I'm not sure how the inner bearing is removed. Do I need a press or a special tool?
Thanks
Mar 5, 2007 at 10:02 AM
BUBBA_KOSKI
  • 129 POSTS
not to take off, the only time you need a press is when packing the rotor (plenty of grease) just be careful not to strip the spindle
Mar 7, 2007 at 8:25 AM
RETIREDAUTO
  • 46 POSTS
it's probably the grease seal holding the bearing in,you must pry out and repl. the seal after you repack the bearings,i am not familiar w/ a sprinter??, but call local auto parts store and see if seal is available first,if so heres how tou cheat. w/ outer bearing removed and rotor still on spindle,re install nut(only) several turns(till spindle is flush w/ end of nut). then pull rotor outward,sliding on spindle w/a quick motion. nut should catch inner bearing and knock out seal. thats the easiest way i can explain it. good luck let me know how it works out for you..
Mar 8, 2007 at 9:59 AM
Suggested Repair
The inner bearing is retained by the grease seal, so a press is not needed to remove it. Confirm a replacement seal is available. With the outer bearing removed and the rotor on the spindle, thread the nut on until it is flush with the spindle end, then pull the rotor outward sharply so the nut catches the inner bearing and knocks out the seal. Pry out any remaining seal, repack the bearings with plenty of grease, and install a new seal. Avoid damaging or stripping the spindle.
Conversation Summary
The owner of a 2003 Dodge Sprinter 2500 with 48,000 miles is replacing the brakes and wants to repack the front wheel bearings. The outer bearing came out easily, but the owner was unsure how to remove the inner bearing and whether a press or special tool was required. One reply said a press is not needed for removal and to avoid stripping the spindle while packing the rotor with grease. Another explained that the grease seal holds the inner bearing and must be replaced after repacking, and described using the spindle nut to knock the seal and bearing out.
