1994 Dodge Spirit Engine timing
TCLINE79
  • 1994 DODGE SPIRIT
Engine Mechanical problem
1994 Dodge Spirit 4 cyl Front Wheel Drive Automatic
How do I set the timing on the 94 dodge spirit
Sunday, January 17th, 2010 AT 4:22 PM
CARADIODOC
  • 33,916 POSTS
Unplug the two-wire coolant temperature sensor to put it into base timing mode. The radiator fan should turn on. Timing marks are on the torque converter. There's a foam rubber plug on top of the bell housing that must be removed. Turn the distributor to adjust the timing.
The Check Engine light will be on during the procedure. When you're done, reconnect the coolant sensor. The fan will turn off. If the Check Engine light doesn't turn off, it will the next time you start the engine.
Caradiodoc
Saturday, January 23rd, 2010 AT 10:55 AM
