1994 Dodge Spirit engine timing
1994 DODGE SPIRIT
99,000 MILES • 4 CYL • FWD • AUTOMATIC
EINDIAN4284
my car seemed to be running good and boom it started to have no power on acceleration and seemed to jump a timing . well the computer is free of all trouble shoot codes . i went to check timing belt .i am having a problem with tdc . the fly wheel mark on "0" where the tdc is ecept the #1 piston is going down and the sprockets marks are all off . so where do i start to making all timing marks linbe up the way they
Oct 16, 2008 at 5:34 AM
  • 110,244 POSTS
Take a look on this page under drive belt routing diagrams. Type in your vehicle info then select timing belt. Make sure you are looking at the right marks and let me know.
If the crank is on TDC, the piston has to be.
Oct 22, 2008 at 6:50 AM
