1994 Dodge Spirit
153965BJ
  • 1994 DODGE SPIRIT
  • 6 CYL
  • 4WD
  • 77,251 MILES
I have a 1994 Dodge Spirit with 77,251 miles on it. The air bag light stay lit and there is a constant dinging like the seatbelt needs to be fasten.
Wednesday, May 27th, 2009 AT 4:05 PM
CARADIODOC
  • 33,916 POSTS
Sounds like two different problems. For the air bag light, suspect a broken clock spring under the steering wheel. Eventually the horn and cruise control won't work either if that's the cause.
Watch when the dinging starts. If it's as soon as you put the key in the ignition, suspect a door switch. Open each door, one at a time, and push the switch in by hand. If the dinging stops, holler back. Many of the switches are adjustable.
Caradiodoc
Friday, June 5th, 2009 AT 2:33 PM
