1991 Dodge Spirit Check engine light
SMS1798
  • 1991 DODGE SPIRIT
  • 4 CYL
  • FWD
  • 125,000 MILES
Check engine light comes on along with check gauges light. When I run heat it'll be slow coming on then it suddenly kicks on to high heat full blast. Gauge for battery goes from 12 to 8 volts. I can't figure out whats wrong.
Sunday, March 2nd, 2008 AT 9:36 PM
SERVICE WRITER
  • 9,123 POSTS
Have your alternater checking for proper output.
Sunday, March 2nd, 2008 AT 9:39 PM
SMS1798
  • 6 POSTS
Thanks will have alternator checked, its a 1992 dodge spirit and voltage meter goes to 8 and sometimes will bounce back to 12. They say check engine light means it has to do with the emmissions - could it need an O2 sensor? Sms1798@hotmail
Tuesday, March 4th, 2008 AT 9:03 PM
SERVICE WRITER
  • 9,123 POSTS
Check engine light is emissions.
Checking the codes in the computer would be a good idea. Although I think it is a by-prouct of the alternater not adequetly charging. The volt meter fluctuation is the biggest concern at this point. THe alternater has to be test when the symptoms are present.
The O2 sensor has to do with fuel/air ratio. I don't believe that this one illuminates base on mileage for an o2 change.
Wednesday, March 5th, 2008 AT 5:52 AM
