Well, got a chance to mess with the flasher replacement yesterday, and it was hard to find! Basically, if you depress the parking break, lie down face-up under the steering wheel, and look up behind the fuse box (scooting your head to where the parking brake would normally be), you will see the sliver-cylinder-Flasher. However, ran into a problem. There was apparently supposed to be 4 Flashers (the square one for the Horn, the skinny one for the Ignition Delay Timing, and 2-short cylinders) However, I only found 3 (Square, Skinny, and one Regular). I yanked the one Regular and tested the Hazards-and yea they didn't work. I was at a loss, and it was late. This morning however, in an epiphany I realized that the same Flasher may serve both purposes. Seems weird though, that it could be for both hazards and turning lights, be broken, and have the hazards still working fine. -anyway,
I got part EL12. This evening I'm going to just try to relpace the single flasher and keep the fingers crossed.
Mar 12, 2008 at 5:35 AM
