1994 Dodge Shadow Temp Gauge Fluctuates
DAVE13
I have a 1994 dodge shadow with 138000 kms. the temp. gauge went to very high, but the car doesn't appear to be overheating. the gauge went back to normal later, but seems to go up and down. I could hear a water sound, and there was wetness down the side of the rad near the belt area. Is my thermostat defective?
Dec 22, 2006 at 1:19 PM
E40WATER12
  • 522 POSTS
What size of motor do u have? 4cyl or V6?. Could have a leaky water pump, Just top up the coolant, And allow it to idle for a 5 to 10 mins, then inspect if u can see an coolant leak, Could also have a bad coolant temp switch, Could give u a faulty reading temp gauge, Also could have HD gasket leak ocuring.
Jun 11, 2007 at 10:16 PM
Suggested Repair
Top up the coolant, idle for 5 to 10 minutes, and inspect for a coolant leak. Check the water pump, coolant temperature switch, and possible head gasket leak rather than assuming the thermostat is defective.
Conversation Summary
The owner of a 1994 Dodge Shadow reported a temperature gauge that rose very high and then fluctuated, despite no clear signs of overheating. They also heard a water sound and saw wetness along the radiator near the belt area, and asked whether the thermostat was defective. The expert asked whether the engine was a four-cylinder or V6 and suggested checking for a leaky water pump, topping up the coolant and inspecting for leaks after idling, a faulty coolant temperature switch, or a developing head gasket leak.
