1992 Dodge Shadow no fluid to rt rear wheel cylinder
280,000 MILES • 4 CYL • 2WD • MANUAL
CHRISVB
  • 6 POSTS
having replaced all the braketubes and bleeding the system , there seems to be no way to get fluid to go to the line for the rt rear wheel , the rest fills normally and i get a hard brake pedal (with the rt rear line disconnected at the proportional valve)
any suggestions??
Nov 27, 2008 at 5:32 AM
  • 31,937 POSTS
Hi there,
If the brake line is disconnected down stream of the proportioning valve i would say that your problem is there, or if up stream in the master cylinder, look here first.
Mark (mhpautos)
Nov 27, 2008 at 7:03 AM
