1993 Dodge Shadow brake booster
1993 DODGE SHADOW
BUBBA2808
Brakes problem
1993 Dodge Shadow 4 cyl Two Wheel Drive Automatic
How do i get the power brake booster off of the car so that i can put the new one on?
Jun 15, 2008 at 3:35 AM
MERLIN2021
  • 17,250 POSTS
From inside under the dash! First, unbolt master and pull forward, then go inside, remove the brake switch from the pedal, slide the booster arm off the pedAL, then remove the four nuts holding it on...
Jun 15, 2008 at 3:39 AM
Take the brake master cyl. out 1st then go behind the firewall to unbolt and unclip it
Jun 15, 2008 at 3:40 AM
