1990 Dodge Shadow trying to get it started
HDACHE13
  • 1990 DODGE SHADOW
1990 Dodge Shadow Two Wheel Drive Automatic
I have a dodge shadow, it has been sitting over 5 years and havent been moved, now I would to put it back to use, what should be my first step to make sure that it is working fine.
Saturday, March 27th, 2010 AT 10:10 PM
  • 109,885 POSTS
I would recommend changing the oil and filter, replacing the fuel in the tank and replace the fuel filter and drain all old gas from the tank, fuel line and throttle body. Make sure all fluids are full. Then see if it will start. Double check wiring under the hood if the vehicle has been parked where mice can get to it. Also, check the air filter for mouse nests.
If it doesn't start, check for fuel pressure and make sure there is spark to the plugs.
Let me know what happens.
Thursday, July 8th, 2010 AT 8:26 PM
