1997 Dodge Ram Temp Gauge Reads 0
SPACEMUNKEY
I have a '97 Dodge Ram 1500 sport pick up. It has a 5.9 liter/360 engine and about 120,000 miles.
I was in an accident last winter and after it was repaired, I noticed that the temprature readout was showing a 0 all the time. However, the compas was still working.
I am wondering what happened. The accident was on the front right side of my truck, so that leads me to believe that it is up in that area somewhere and was damaged. Do you know where it is and how and how much to fix it?
May 11, 2007 at 2:53 PM
SERVICE WRITER
  • 9,123 POSTS
Test the coolant temp sender. Turn ignition on, disconnect the temp sender connector. run a jumper wire from the connector to a ground. IF the gauge reads high now, replace the sender. If not we can gor from here.
May 11, 2007 at 3:29 PM
Suggested Repair
With the ignition on, disconnect the coolant temperature sender connector and jumper it to ground. If the gauge then reads high, replace the sender; if not, continue diagnosis.
Conversation Summary
The owner of a 1997 Dodge Ram 1500 says the temperature readout stays at 0 after a front-right accident repair, while the compass still works. The expert recommends testing the coolant temperature sender by grounding its connector with the ignition on and replacing the sender if the gauge then reads high.
