System to Lean
SUTTON12312
1998 Dodge Ram 1500 4x4 123,000 miles.
Check engine light came on, truck was running bad. Had new cap and rotar put on, new air filter and changed spark plugs. The plugs were totally black. I cant imagine how they fired.
check engine light is stillon. had it coded and it blew a 170 or something but it was a system to lean. the truck runs good upon first starting but gettin down the road it hesitates some and just doesnt make the power it used to. any help would be apprecited
Sep 8, 2007 at 12:44 PM
  • 75,988 POSTS
[quote:5d63da7f24="sutton12312"]1998 Dodge Ram 1500 4x4 123,000 miles.
check engine light is stillon. had it coded and it blew a 170 or something but it was a system to lean. the truck runs good upon first starting but gettin down the road it hesitates some and just doesnt make the power it used to. any help would be apprecited[/quote:5d63da7f24]
P0170....Fuel Trim (Bank 1) have the oxygen sensor and fuel pressure check
Sep 9, 2007 at 2:25 AM
ROCKWOOD84
  • 103 POSTS
try putting a throttle position sensor on as this tells the pcm where the throttle plate is.if it is bad it will set a whole lot of codes off.
Sep 9, 2007 at 3:26 PM
