starting problem on 1995 3.9L ram b2500 van
1HAPPYCAMPER
hi,, when i turn the ignition i get a click- turn it again sometimes another click sometimes a GLUG type sound (no click when this sound is heard) -- it will start if i persist (usually within 5 tries). I have been told it is a starter problem (which should be replaced)and i have been told it is a alternaor problem. The belt tensioner also i have been told needs replacing! (though the belt seems fine -no tears) . I have been told the alternator was bad and wasnt charging the battery-that i was running on just the battery but the battery is fully charged!. My battery leads are alittle worn (no corrosion just breaks ) I read that if it is a starter problem replacing the copper wires inside the starter will correct the problem .The van has only 77k on it. What do you think it is?Tnks i really dont want to get ripped off ,your opinion needed bad..Oh ,also there is a squeal (not always heard) coming from the engine compartment (belt tensioner ?alternator?)Hope that helps.
Feb 16, 2007 at 1:35 PM
KIN CHAN
  • 453 POSTS
sounds like an ignition switch problem cuz u mentioned if upon persistant for 5 times then it'll start....get underneath by the start ...there should be a smaller wire to the starter solenoid next to the battery big cable...chk if there is battery voltage present when someone inside the car crank it..if u see none...jump it across the battery +ve terminal ...the starter should kick in ....further repair need wiring diagram and auto repair skill ....
Feb 16, 2007 at 9:03 PM
