replaced water pump that still leaks
RUSTYSPOONS
1999 Dodge Ram (Sport) 1500 4x4 V-8 92000 miles..
The water pump went out so i had it replaced by a relative that is a mechanic. He made sure that he sealed it as well as tighten all the bults. As far as he knows he didnt miss a step, however antifreeze is still leaking and i'm almost positive it isn't faulty. I've tired stop-leak (only because this truck is my only means of transportation) so far that doesn't seem to stop the leaks either. i'm just wondering if there is a way to fix this with out having to take the water pump back off.Thanks..
Sep 19, 2007 at 11:00 AM
MERLIN2021
  • 17,250 POSTS
Can you see where it comes from? Is it a fast or slow leak?Some chrysler engines have a water tube under the intake manifold that runs from fron to back, usually in front drive models. But a pressure test will help you find it quick! It could be an intake manifold leak at the front corner...
Sep 19, 2007 at 11:35 AM
